This Product Selection Guide contains information to help select products in the Image Sensors, Camera category on DigiKey.com
Products in the image sensor and camera family are component or module-level devices used to electronically capture visual information in the visible and/or infrared spectrums. Consisting of an array of photosensitive elements connected to a shared control and interface mechanism, available products include those adapted to common still image and video capture as well as more specialized applications such as thermal and spatial imaging.
SelectionCharacteristics
Type: Indicates the technology being used for the sensing.
Pixel Size: Indicates the physical dimensions of the imaging pixel used in the sensor.
Active Pixel Array: The number of horizontal and vertical subdivisions of the usable imaging area; maximum image resolution.
Frames per Second: Indicates the maximum number of full-frame images per second that an image sensor is capable of transferring.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | OVM7692-RAAA |
| DIGIKEY PART # | 884-1028-2-ND - Tape & Reel (TR) |
| MANUFACTURER | OmniVision Technologies Inc |
| DESCRIPTION | CMOS with Processor Image Sensor 640H x 480V 1.75µm x 1.75µm |
| MFR PART # | EPC611-CSP24-001 |
| DIGIKEY PART # | 2199-EPC611-CSP24-001TR-ND - Tape & Reel (TR) |
| MANUFACTURER | ESPROS Photonics AG |
| DESCRIPTION | 3D Time of Flight Image Sensor 8H X 8V 8µm x 8µm |
| MFR PART # | ASX350AT3C00XPEA0-DR |
| DIGIKEY PART # | ASX350AT3C00XPEA0-DR-ND |
| MANUFACTURER | onsemi |
| DESCRIPTION | CMOS Image Sensor 3.75µm x 3.75µm 63-IBGA (7.5x7.5) |
MediaLinks
Videos
Enhanced NIR sensitivity from Interline Transfer CCD Image Sensors
