This Product Selection Guide contains information to help select products in the Specialized Cable Assemblies category on DigiKey.com
Products in the specialized cable assembly family incorporate cordage and connectors in combinations that are purpose specific, non-standard, uncommon, or which are otherwise ill-suited for classification among cable assemblies of some other type. Grounding and bonding straps, photovoltaic power cables, and backplane cables are among included products.
SelectionCharacteristics
Type: Defines the type, style, or configuration of the specialized cable assembly.
Number of Lines: Indicates the number of galvanically isolated current paths that pass through a device.
Cable Length - Unexposed: Length of cable assembly. For assemblies incorporating a flexible protective conduit, the length of the protected portion.
Features: These are different capabilities or properties of the device such as shielded or IP ratings.
IP Ratings
IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
ProductExamples
| MFR PART # | 74273704 |
| DIGIKEY PART # | 732-10304-ND |
| MANUFACTURER | Würth Elektronik |
| DESCRIPTION | Cable Earthing Belt Line 0.67’ (0.20m) 7.87" |
| MFR PART # | AYG5V15085M1 |
| DIGIKEY PART # | AYG5V15085M1-ND |
| MANUFACTURER | Panasonic Electric Works |
| DESCRIPTION | Cable Optical Connector Plug to Wire 2 Line 1.64’ (0.50m) 19.69" |
| MFR PART # | 2213759-3 |
| DIGIKEY PART # | A142175-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Cable Photovoltaic Pin Connector to Photovoltaic Socket Connector 1 Line 1.64’ (0.50m) 19.69" |
| MFR PART # | 2033879008 |
| DIGIKEY PART # | 900-2033879008-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Cable Backplane, 4 Pair, 8 Column to Backplane, 4 Pair, 12 Column 64, 96 Line 1.64’ (0.50m) 19.69" |
