This Product Selection Guide contains information to help select products in the Encoders, Decoders, Converters category on DigiKey.com
Products in this family are used to package or encipher information into a format suitable for transmission or storage, and/or to perform the inverse operation at the other end of a communications path, typically through the use of some form of modulation process. Examples include devices that generate an analog video signal from digital data (or vice-versa), devices that encode the status of buttons for transmission to implement remote control functions, and devices that facilitate connection of a standard UART to a standard infrared transceiver.
SelectionCharacteristics
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Voltage - Supply, Analog: Describes the permitted operating range of the supply voltage required for powering the analog portion of a mixed-signal device. Voltages outside this range may damage the device and other system components.
Voltage - Supply, Digital: Describes the permitted operating range of the supply voltage required for powering the digital portion of a mixed-signal device. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | MCP2122T-E/SN |
| DIGIKEY PART # | MCP2122T-E/SNTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | IC ENCODER/DECODER IRDA 8-SOIC |
| MFR PART # | ADV7393BCPZ |
| DIGIKEY PART # | 505-ADV7393BCPZ-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC DAC VIDEO HDTV 10BIT 40LFCSP |
| MFR PART # | TVP5150AM1PBS |
| DIGIKEY PART # | 296-32781-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | IC VIDEO DECODER 8BIT 32TQFP |
MediaLinks
Videos
Videos on Encoders
Articles
A Designers Guide to Encoders
Absolute Encoder Communication Protocols Guide
Articles on Encoders
Articles on Decoders
Product Training Modules
Encoders and Decoders
Remote Control and Remote Keyless Entry
Product Training Modules on Encoders
Blogs
Input Control for Everyday Projects: Rotary Encoders and Potentiometers
Smarter Motion Control for Smart Manufacturing
Blogs on Encoders
TechForum
Beginners Guide to the Quadrature Encoder
Design a Robust Quadrature Encoder ISR based program for Arduino Motor Control
How to Configure the Modicon PLC for a Quadrature Encoder
Quadrature Decoder (VHDL
TechForum Posts on Encoders
TechForum Posts on Decoders
