This Product Selection Guide contains information to help select products in the Cables, Wires - Single Conductors category on DigiKey.com
Single conductor wires are composed of a solid strand of copper with color-coded PVC insulation. They are used when wire forming is required for routing or wire wrapping. Common uses include hooking up circuits either on PCBs as through-hole or wire wrap conductors, or for breadboard prototyping as poke-in circuit paths. Single strand wire and cable is more durable than stranded wire but is not recommended for excessive or frequent flexing.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Values: Indicates the number and/or type of items the kit contains.
ProductExamples
| MFR PART # | 18UL1007STRKIT |
| DIGIKEY PART # | 2328-18UL1007STRKIT-ND |
| MANUFACTURER | Remington Industries |
| DESCRIPTION | Hook Up Wire, 18 AWG Kit 6 Spools, 25 ft each |
| MFR PART # | 3174 |
| DIGIKEY PART # | 1528-1745-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | Hook Up Wire, 22 AWG Kit 10 Spools, 25 ft each |
| MFR PART # | PRT-11367 |
| DIGIKEY PART # | 1568-1357-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | Hook Up Wire, 22 AWG Kit 6 Spools, 25 ft each |
