This Product Selection Guide contains information to help select products in the Magnets category on DigiKey.com
SelectionCharacteristics
Depth (Inches): Indicates the overall depth of the device.
Width (Inches): Indicates the overall width of the device.
Height (Inches): Indicates the overall height of the device.
Construction: Indicates the material composition of the device.
Cleaning Width: The distance from which the magnet is nominally able to attract material to it.
Lifting Power: The total amount of material the item is able to nominally collect and keep next to it as the item is being moved around.
Color: The dominant color of the device.
ProductExamples
MFR PART # | 261286 |
DIGIKEY PART # | 3539-261286-ND |
MANUFACTURER | IndustrialSupplies.com |
DESCRIPTION | Aluminum/Steel 400 lbs Magnetic Sweeper |
MFR PART # | EC18 |
DIGIKEY PART # | 3539-EC18-ND |
MANUFACTURER | A.M.K. Magnetics Inc |
DESCRIPTION | Aluminum/Steel 50 lbs Magnetic Sweeper |
MFR PART # | PXL |
DIGIKEY PART # | 3539-PXL-ND |
DESCRIPTION | Aluminum/Steel/Plastic 25 lbs Hand Release Magnet |
