This Product Selection Guide contains information to help select products in the Punches category on DigiKey.com
Products in this family are hand tools used to transfer impact forces supplied by a hammer or similar striking tool to a specific location on a workpiece. Through variations in the shape of the tool face that is placed in contact with the workpiece, they are adapted to different common purposes, such as creating an indentation in the workpiece or forcing objects out of tight fitting holes. Note that these products may be sold either as individual items or as sets of varying sizes.
SelectionCharacteristics
Type: Indicates the style and configuration of the tool.
Tip Diameter: Indicates the diameter of the tip of the tool.
Shaft Diameter: Indicates the diameter of the shaft of the tool.
Length: Indicates the overall length of the tool.
ProductExamples
| MFR PART # | P-5 PUNCH |
| DIGIKEY PART # | 1772-3348-ND |
| MANUFACTURER | RAF Electronic Hardware |
| DESCRIPTION | DIA X Length |
| MFR PART # | 4BPSET5 |
| DIGIKEY PART # | 4BPSET5-ND |
| MANUFACTURER | Klein Tools, Inc. |
| DESCRIPTION | Parallel Pin Punch, Set of 5 Assorted DIA X Assorted Length |
| MFR PART # | 4PPLSET8 |
| DIGIKEY PART # | 4PPLSET8-ND |
| DESCRIPTION | Parallel Pin Punch, Set of 8 Assorted DIA X Assorted Length |
