This Product Selection Guide contains information to help select products in the Patchbay, Jack Panel Accessories category on DigiKey.com
Patchbays and jack panels are arrays of connectors of similar type or kind, used for routing or interconnecting large numbers of signal paths in applications such as data centers or distribution points for wired network infrastructure. Products in this family are ancillary to or supportive of items including mounting hardware, cable strain reliefs, items used for marking or identification, plugs for empty connector spaces, and others.
SelectionCharacteristics
Accessory Type: The type, style, or form factor of accessory being offered.
Style: The style of connection the accessory is designed to interface with.
Includes: What an order of a single piece of the accessory includes when shipped.
ProductExamples
| MFR PART # |
QSP48HDBL |
| DIGIKEY PART # |
298-12855-ND |
| MANUFACTURER |
Panduit Corp |
| DESCRIPTION |
48-PORT SHIELDED HIGH DENSITY PA |
| DATASHEET |
Click Here |
| MFR PART # |
VMTPUHD |
| DIGIKEY PART # |
SC3542-ND |
| MANUFACTURER |
Switchcraft Inc. |
| DESCRIPTION |
DUAL TERMINATING PLUG |
| DATASHEET |
Click Here |
| MFR PART # |
FQCRCM |
| DIGIKEY PART # |
298-12691-ND |
| MANUFACTURER |
Panduit Corp |
| DESCRIPTION |
QUICKNET CASSETTE REAR CABLE |
| DATASHEET |
Click Here |
| MFR PART # |
TT5152 |
| DIGIKEY PART # |
TT5152-ND |
| MANUFACTURER |
Switchcraft Inc. |
| DESCRIPTION |
PLUG DUMMY MINI 2-3 COND BLACK |
| DATASHEET |
Click Here |
| MFR PART # |
HP-437 |
| DIGIKEY PART # |
1097-1326-ND |
| MANUFACTURER |
Cinch Connectivity Solutions Trompeter |
| DESCRIPTION |
.437" PATCH PANEL HOLE PLUG |
| DATASHEET |
Click Here |
| MFR PART # |
N492-WM2-BK |
| DIGIKEY PART # |
N492-WM2-BK-ND |
| MANUFACTURER |
Tripp Lite |
| DESCRIPTION |
FIBER OPTIC WALLMOUNT DISTRIBUTI |
| DATASHEET |
Click Here |
| MFR PART # |
T3PPB |
| DIGIKEY PART # |
T3PPB-ND |
| MANUFACTURER |
HellermannTyton |
| DESCRIPTION |
2U WLL MNT PTCH PNL BRCKT |
| DATASHEET |
Click Here |
| MFR PART # |
N484-3M8-LC12 |
| DIGIKEY PART # |
N484-3M8-LC12-ND |
| MANUFACTURER |
Tripp Lite |
| DESCRIPTION |
40GB-10GB BREAKOUT CASSETTE |
| DATASHEET |
Click Here |
If you have any general questions on the specifications for selecting Patchbay, Jack Panel Accessories, please reply using the button below. If you have questions on specific Patchbay, Jack Panel Accessories please post those questions in the Equipment, Tools & Supplies category.
