This Product Selection Guide contains information to help select products in the Panel Meters - Accessories category on DigiKey.com
Panel Meter Accessories includes an accessory board, adapter plate, bezel, cable assembly, cam, cam pin, connector, current transformer, damper, DC current shunt, display, enclosure, evaluation board, expansion module, front cover, front panel, hardware, hole plug, option card, panel cutout punch, programming box, rubber gasket, shroud, and terminals.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: This selection indicates the attributes which expound on a product’s abilities, but are not a standard attribute universal to this product family.
Includes: Indicates items included with purchase.
ProductExamples
| MFR PART # | DMS-BZL1-C |
| DIGIKEY PART # | 811-2671-ND |
| MANUFACTURER | Murata Power Solutions Inc. |
| DESCRIPTION | Bezel Rectangular 64.77mm x 32.26mm Outside Dim |
| MFR PART # | PAXCDL10 |
| DIGIKEY PART # | RLC194-ND |
| MANUFACTURER | Red Lion Controls |
| DESCRIPTION | Option Card, Output Analog |
| MFR PART # | MCETH |
| DIGIKEY PART # | 1864-2501-ND |
| MANUFACTURER | Carlo Gavazzi Inc. |
| DESCRIPTION | Option Card, Communications |
| MFR PART # | J1C13 |
| DIGIKEY PART # | CDPM1004-ND |
| MANUFACTURER | C-TON Industries |
| DESCRIPTION | Cable Assembly Wiring Harness, 13 Position, 26AWG |
