This Product Selection Guide contains information to help select products in the Motors, Actuators, Solenoids, and Drivers - Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Usage: The typical expected usage the manufacturer designed the device for.
Specifications: This selection indicates the attributes which expound on a product’s abilities but are not a standard attribute universal to this product family.
ProductExamples
| MFR PART # |
MFECA0030EAM |
| DIGIKEY PART # |
1110-3066-ND |
| MANUFACTURER |
Panasonic Industrial Automation Sales |
| DESCRIPTION |
Cable Assembly 3 Meters |
| MFR PART # |
3G3AX-MX2-ECT |
| DIGIKEY PART # |
Z7875-ND |
| MANUFACTURER |
Omron Automation and Safety |
| DESCRIPTION |
Option Card, Communications EtherCAT |
| DATASHEET |
Click Here |
| MFR PART # |
79265119 |
| DIGIKEY PART # |
966-1766-ND |
| MANUFACTURER |
Crouzet |
| DESCRIPTION |
Brush |
| MFR PART # |
ROB-12105 |
| DIGIKEY PART # |
1568-1352-ND |
| MANUFACTURER |
SparkFun Electronics |
| DESCRIPTION |
Enclosure Chassis Mount |
| DATASHEET |
Click Here |
| MFR PART # |
BR200W360 |
| DIGIKEY PART # |
BR200W360-ND |
| MANUFACTURER |
Delta Electronics/Industrial Automation |
| DESCRIPTION |
Braking Resistor 360Ohm, 200W |
| DATASHEET |
Click Here |
| MFR PART # |
R88A-TK01K |
| DIGIKEY PART # |
Z9991-ND |
| MANUFACTURER |
| DESCRIPTION |
Mounting Bracket Rack Mount |
| DATASHEET |
Click Here |
| MFR PART # |
MZ9G5B |
| DIGIKEY PART # |
1110-4221-ND |
| MANUFACTURER |
| DESCRIPTION |
Gearbox 1/5 Ratio |
| DATASHEET |
Click Here |
If you have any general questions on the specifications for selecting Motors, Actuators, Solenoids, and Drivers - Accessories, please reply using the button below. If you have questions on specific Accessories please post those questions in the Motors, Actuators, Solenoids, and Drivers category.
