This Product Selection Guide contains information to help select products in the Hinges category on DigiKey.com
A Hinge is a two piece jointed part that is connected to a top and bottom, a door and post, so that one piece is stationary and the other piece rotates on a the fixed axis point. The types of hinges are concealed, elbow, knuckle, leaf, lift off, and side hinge being made of brass, plastic, polyamide, stainless steel, steel, or zamak (zinc alloy).
SelectionCharacteristics
Type: Identifies the specific style of hinge.
Rotation Angle: Indicates the angular range of motion of a device’s actuator.
Material: Indicates the material composition of the hinge.
Plating: Indicates the finish/plating material applied to the hinge.
ProductExamples
| MFR PART # | 89963001 |
| DIGIKEY PART # | RPC2694-ND |
| MANUFACTURER | Essentra Access Solutions |
| DESCRIPTION | LIFT OFF LEAF HINGE RH 100X75 ST |
| MFR PART # | 1199201 |
| DIGIKEY PART # | RPC2427-ND |
| DESCRIPTION | HEAVY DUTY STYLED HINGE 50X50 PO |
| MFR PART # | 5931125 |
| DIGIKEY PART # | RPC2668-ND |
| DESCRIPTION | SIDE MOUNTED HINGE ZAMAK CHROME |
