This Product Selection Guide contains information to help select products in the Latches, Locks category on DigiKey.com
Latches and Locks are designed to secure anything from cabinets to machine covers to toolboxes. The types include cam latch, cam latch/padlockable, cam lock, compression latch, compression lock, L-handle cam latch, L-handle cam lock, lift and turn latch, rotating, slam cam latch, sliding lock, swell latch, swinghandle, T-handle cam latch, T-handle cam lock, T-handle compression latch, and T-handle compression lock.
SelectionCharacteristics
Type: The type, style, or form factor of device being offered.
Panel Cutout Dimensions: Describes the dimensions of the hole in the panel the device is designed to occupy. Panel cutout comes in a variety of shapes, and is given in Millimeters.
Mounting Type: How the device is intended to be mounted into the object it’s being attached to.
Material: The dominant material of the device.
ProductExamples
MFR PART # | 270201 |
DIGI-KEY PART # | RPC2521-ND |
MANUFACTURER | Essentra Access Solutions |
DESCRIPTION | Swell Latch Cutout Screw, Bolt Polyamide |
DATASHEET | Click Here |
MFR PART # | SSLL-KIT |
DIGI-KEY PART # | 2321-SSLL-KIT-ND |
MANUFACTURER | Integra Enclosures |
DESCRIPTION | Sliding Lock Cutout Clip In Stainless Steel |
MFR PART # | MHKD1 |
DIGI-KEY PART # | HM5538-ND |
MANUFACTURER | Hammond Manufacturing |
DESCRIPTION | Rotating Cutout Screw Holes, Back Zinc |
MFR PART # | FIT0620 |
DIGI-KEY PART # | 1738-FIT0620-ND |
MANUFACTURER | DFRobot |
DESCRIPTION | Cutout Screw Holes, Back Steel |
MediaLinks
Videos
