This Product Selection Guide contains information to help select products in the KVM Switches (Keyboard Video Mouse) - Cables category on DigiKey.com
KVM (keyboard-video-mouse) adaptor cables are designed for use with KVM switches, which allow for selecting between peripherals and protocols and account for differences in connector types. Common adaptations include D-Sub 15 position connectors to USB, mini DIN, DVI-D dual link, RJ45, 3.5 mm, and HDMI. Cables are selected by length and compatible KVM switch used.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Convert From (Adapter End): Type or style of connection being converted from.
Confert To (Adapter End): Type or style of connection being converted to.
Length: The length of the cable, this length may or may not include the connectors. Please consult the individual datasheets.
ProductExamples
| MFR PART # | P783-006-DPU |
| DIGIKEY PART # | 95-P783-006-DPU-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | DISPLAYPORT KVM CABLE KIT - DP, |
| MFR PART # | 500-198-R-ACC |
| DIGIKEY PART # | 1829-1108-ND |
| MANUFACTURER | Lantronix, Inc. |
| DESCRIPTION | PS/2, LOCAL INPUT, STANDARD 21.6 |
| MFR PART # | B055-001-USB-V2 |
| DIGIKEY PART # | TL2002-ND |
| DESCRIPTION | SDS ETHERNET TO USB 1-PORT |
| MFR PART # | B032-VU2 |
| DIGIKEY PART # | TL1999-ND |
| DESCRIPTION | 2-PORT USB/VGA CABLE KVM SWITCH |
