This Product Selection Guide contains information to help select products in the Electrical Testers, Current Probes category on DigiKey.com
Electrical testers and current probes are devices that are designed to measure or test for an electrical condition which could include any or a combination of voltage, resistance, current, capacitance, frequency, etc. The types of equipment found in this category include: continuity tester, current meter, earth ground tester, electrical tester, GFCI, 3-wire circuit tester, phase rotation indicator, power quality analyzer, voltage detector, and many more.
SelectionCharacteristics
Specifications: This selection indicates the attributes which expound on a product’s abilities, but are not a standard attribute universal to this product family.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
ProductExamples
| MFR PART # | FLUKE-377 FC |
| DIGIKEY PART # | 614-FLUKE-377FC-ND |
| MANUFACTURER | Fluke Electronics |
| DESCRIPTION | Current Meter, Clamp/Probe CAT III 1000V, CAT IV 600V DMM Functions Include Voltage, Resistance, Temperature, Frequency and Current to 2500A |
| MFR PART # | CL800 |
| DIGIKEY PART # | 1742-1206-ND |
| MANUFACTURER | Klein Tools, Inc. |
| DESCRIPTION | Current Meter, Clamp/Probe CAT III 1000V, CAT IV 600V DMM Functions Include Voltage, Resistance, Capacitance, Temperature, Frequency and Current to 600A |
| MFR PART # | VS-AVT-C08-L10 |
| DIGIKEY PART # | 298-11982-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Voltage Detector CAT IV 600V Measures AC, DC Voltage to 600V |
MediaLinks
Videos
Fluke T6 Electrical Testers - FieldSense Technology Lets You Measure Voltage Without Test Leads
iFlex™ Flexible Current Probe
It’s a Tight, Tight World! Fluke Clamps
Articles
Understanding, Selecting, and Effectively Using Current Probes
Blogs
How to Measure Current in a Circuit
The Basics of Choosing a Multimeter
Additional Product Features Can Prove Worthwhile
TechForum
Measuring AC Current with Clamp Probes
Fluke Test Leads Probes Kits and Equipment
