This Product Selection Guide contains information to help select products in the Test and Measurement Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Type: A general description of the item.
Accessory Type: The type, style, or nature of the accessory.
Specifications: This selection indicates the attributes which expound on a product’s abilities, but are not a standard attribute universal to this product family.
ProductExamples
| MFR PART # | BU-32-9 |
| DIGIKEY PART # | 314-1564-ND |
| MANUFACTURER | Mueller Electric Co |
| DESCRIPTION | Test Clip, Lead, Probe Insulator, White for use with Alligator Clips: BU-30, BU-30C |
| MFR PART # | S19-501 |
| DIGIKEY PART # | 952-2614-ND |
| MANUFACTURER | Harwin Inc. |
| DESCRIPTION | Test Clip, Lead, Probe Sleeve for use with P19-xx21 Series |
| MFR PART # | DIP-IC5A-BK |
| DIGIKEY PART # | 4672-DIP-IC5A-BK-ND |
| MANUFACTURER | MH Connectors |
| DESCRIPTION | Test Clip, Lead, Probe Insulator, Black for use with |
