This Product Selection Guide contains information to help select products in the Display Drivers category on DigiKey.com
Display drivers are integrated circuits (ICs) that provide translation, interface and control between a microprocessor (MPU), microcontroller (MCU) or other circuitry system for displays such as LCD, LED, OLED, DLP, vacuum fluorescent and AMOLED. Possible interfaces and protocols for communication include analog, BCD, I2C, parallel, serial, SMBus, SPI and QSPI.
SelectionCharacteristics
Display Type: Indicates the type or style of the display the driver is intended to function with
Configuration: Indicates the display configuration the device is designed to drive.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Digits or Characters: Indicates the number of segmented-display characters, digits, or individual display segments that the device is able to control.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | MAX6922AQH+TD |
| DIGIKEY PART # | MAX6922AQH+TDTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Vacuum Fluorescent (VF) Driver 44-PLCC (16.59x16.59) |
| MFR PART # | MC14511BDG |
| DIGIKEY PART # | MC14511BDGOS-ND |
| MANUFACTURER | onsemi |
| DESCRIPTION | LED, LCD, Vacuum Fluorescent (VF) Driver 16-SOIC |
| MFR PART # | HV5812P-G |
| DIGIKEY PART # | HV5812P-G-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Vacuum Fluorescent (VF) Driver 28-PDIP |
| MFR PART # | PCA8561AHN/AY |
| DIGIKEY PART # | 568-13032-2-ND - Tape & Reel (TR) |
| MANUFACTURER | NXP USA Inc. |
| DESCRIPTION | LCD Driver 32-HVQFN (5x5) |
MediaLinks
Videos
Videos On Display Drivers
Articles
Articles on Display Drivers
Product Training Modules
Simple LED Drivers- MAX7219 and MAX7221 - Maxim | DigiKey
Blogs
Selecting the Right Display for My Project
TechForum
7-Segment Display Driver for Multiple Digits (VHDL)
TechForum Posts on Display Drivers
MediaLinks
CP240x LCD Driver Family - Silicon Labs
