This Product Selection Guide contains information to help select products in the Variable Capacitance (Varicaps, Varactors) category on DigiKey.com
Variable capacitance diodes are produced and characterized for use as electronically-variable capacitors, and are widely used in tuning and frequency synthesis applications. While most all diodes exhibit a junction capacitance that decreases as the amount of reverse bias voltage applied increases and are capable of functioning as variable capacitance diodes, products specifically marketed as such are produced and characterized with this use in mind.
SelectionCharacteristics
Capacitance @ Vr, F: Characterizes the capacitance exhibited by a device when reverse-biased, at the indicated values of reverse voltage and test frequency.
Capacitance Ratio: Typical ratio of device capacitances measured at two specified reverse bias voltages, the choice of which often implies the bias range over which the capacitance vs. bias relationship is approximately linear.
Capacitance Ratio Condition: Indicates measurement conditions for the listed capacitance ratio. For example, “C0.1/C4” signifies a ratio measured with 0.1v and 4v of reverse bias.
Voltage - Peak Reverse (Max): The maximum voltage that should be allowed to appear across a device during normal operation. Exceeding this voltage may damage the device or other system components.
Diode Type: Describes the internal diode configuration of the device and its connections.
Q @ Vr, F: A figure of merit describing a device’s resonant qualities, and the reverse bias voltage and test signal frequency at which the given value is measured.
ProductExamples
| MFR PART # | SMV1236-079LF |
| DIGIKEY PART # | 863-1135-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Skyworks Solutions Inc. |
| DESCRIPTION | Varactors Single 15 V Surface Mount SC-79 |
| MFR PART # | MAVR-011020-14110P |
| DIGIKEY PART # | 1465-1782-2-ND - Tape & Reel (TR) |
| MANUFACTURER | MACOM Technology Solutions |
| DESCRIPTION | Varactors Single 22 V Surface Mount 2-FlipChip |
| MFR PART # | KVX2122-23-0 |
| DIGIKEY PART # | 150-KVX2122-23-0-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Varactors Single 22 V Surface Mount SOT-23-3 |
| MFR PART # | BB135,115 |
| DIGIKEY PART # | 568-6035-2-ND - Tape & Reel (TR) |
| MANUFACTURER | NXP USA Inc. |
| DESCRIPTION | Varactors Single 30 V Surface Mount SOD-323 |
SchematicSymbol
MediaLinks
Videos
Murata LXRW Series Variable Capacitors | DigiKey Daily
Articles
The Fundamentals and Application of Zener, PIN, Schottky, and Varactor Diodes
