This Product Selection Guide contains information to help select products in the D-Sub, D-Shaped Connector Jackscrews category on DigiKey.com
Jack Screws or Screw Lock assemblies solidify the connection between D-Sub connectors by physically screwing the male and female connectors together. It is important to note that some jackscrews come with hardware included, while others require additional hardware that is not included.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Features: These are different capabilities or properties of the device such as a clip or washers.
Length - Threaded Portion Below Head: Indicates the length of the portion of the shaft below the head of the part that is threaded.
Length - Below Head: Indicates the length of the shaft that is below the head of the part.
Thread Size: Indicates the thread size of compatible parts. For more information on screw sizes see Choosing a Screw by the Thread Size.
ProductExamples
| MFR PART # | 5205818-3 |
| DIGIKEY PART # | 5205818-3-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Jackscrew Socket For AMPLIMITE Series HDF, HDP |
| MFR PART # | 7244-5 |
| DIGIKEY PART # | 36-7244-5-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | Jackscrew Socket For D-Sub Connectors |
| MFR PART # | JSX-1000 |
| DIGIKEY PART # | 2092-JSX-1000-ND |
| MANUFACTURER | Kycon, Inc. |
| DESCRIPTION | Jackscrew For D-Sub Connectors |
