This Product Selection Guide contains information to help select products in the Evaluation Boards - Audio Amplifiers category on DigiKey.com
Audio Amplifier Evaluation boards are populated boards used to provide a working example of a specific analog amplifier or device. The amplifier types are Class AB, Class D, Class G, Class H, and Class K, with output types of headphone, 1 channel (mono), 2 channel (stereo), 3 channel, 4 channel, 6 channel, and 8 channel.
SelectionCharacteristics
Amplifier Type: Indicates the operational mode(s) of a featured amplifier IC, which has categorical significance for performance traits such as electrical efficiency.
Output Type: Indicates which type of audio output is provided, whether stereo or mono, and how many channels of output are available.
Max Output Power x Channels @ Load: Indicates manufacturer’s rated output power for a device, as a function of channel configuration and nominal load impedance.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Board Type: Indicates the extent to which a board has been populated.
Utilized IC / Part: Indicates the central integrated circuit the device is designed around.
Supplied Contents: Indicates items included with purchase.
ProductExamples
| MFR PART # | TPA3255EVM |
| DIGIKEY PART # | 296-46782-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | TPA3255 PurePath™ 1-Channel (Mono) or 2-Channel (Stereo) Output Class D Audio Amplifier Evaluation Board |
| MFR PART # | DFR0119 |
| DIGIKEY PART # | 1738-1068-ND |
| MANUFACTURER | DFRobot |
| DESCRIPTION | PAM8403 - 2-Channel (Stereo) Output Class D Audio Amplifier Evaluation Board |
| MFR PART # | 1752 |
| DIGIKEY PART # | 1528-1031-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | MAX9744 - 2-Channel (Stereo) Output Class D Audio Amplifier Evaluation Board |
| MFR PART # | DEMOBASSAMP60W1270TOBO1 |
| DIGIKEY PART # | 448-DEMOBASSAMP60W1270TOBO1-ND |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | MA12070 MERUS™ 2-Channel (Stereo) Output Class D Audio Amplifier Evaluation Board |
MediaLinks
Videos
Mono Audio Power Amplifiers Evaluation Board - NCP2823BGEVB
2 x 37 W, inductorless multilevel class D amplifier - Infineon Technologies
How to Obtain Constant Audio Output Levels Using the MAX9814
Articles
Adding Class D Audio to Your Embedded Design
Other Articles on Audio Amplifiers
Product Training Modules
Class D Audio Amplifiers - NXP
TechForum
TechForum posts on Audio Amplifiers
