This Product Selection Guide contains information to help select products in the Evaluation and Demonstration Boards and Kits category on DigiKey.com
Products within this family provide a convenient means of evaluating the performance or behavior of some focus device, in the context of a proven implementation that is generally well-documented and supported by evaluation software, as appropriate. Typically consisting of a printed circuit board on which the focus device has been populated along with necessary or helpful support components, additional components such as cabling or power supplies may also be included. Evaluation platforms for device classes that are particularly numerous or distinctive in their classification such as ADCs, DACs, and switch-mode power supplies may be grouped together as a separate product family.
SelectionCharacteristics
Type: Indicates the broad technology category the device being evaluated or demonstrated falls into.
Function: Indicates the primary function of the device being evaluated or demonstrated.
Embedded: Indicates whether or not an evaluation board/kit incorporates a processor of some type, and provides a rudimentary description of such if present.
Utilized IC / Part: Indicates the central integrated circuit the device is designed around.
Primary Attributes: Provides a brief description of device function, purpose, capabilities, or hardware provisions.
Supplied Contents: Indicates items included with purchase.
ProductExamples
| MFR PART # | EPC9512 |
| DIGIKEY PART # | 917-1155-ND |
| MANUFACTURER | EPC |
| DESCRIPTION | Wireless Power Supply/Charging Power Management Evaluation Board |
| MFR PART # | NRF-PPK2 |
| DIGIKEY PART # | 1490-NRF-PPK2-ND |
| MANUFACTURER | Nordic Semiconductor ASA |
| DESCRIPTION | Current Monitor Power Management Evaluation Board |
| MFR PART # | CP2102N-MINIEK |
| DIGIKEY PART # | 336-3914-ND |
| MANUFACTURER | Silicon Labs |
| DESCRIPTION | CP2102N USB 2.0 to UART (RS232) Bridge Interface Evaluation Board |
| MFR PART # | TMC5072-EVAL-KIT |
| DIGIKEY PART # | 1460-1135-ND |
| MANUFACTURER | Trinamic Motion Control GmbH |
| DESCRIPTION | TMC5072 Motor Controller/Driver, Stepper Power Management Evaluation Board |
MediaLinks
Videos
LDO Linear Regulator Evaluation Boards - NCP702MX Series
Ultra High Voltage Regulator Evaluation Boards - NCP785AHGEVB
Other Evaluation Board Videos
Articles
Development and Evaluation Boards for Serial Sensor Systems
Development Kits Let Designers Check Out Single Components to Systems-on-a-chip for Wireless Designs
Use Development Boards in Industrial Applications as Single Board Computers
Other Articles on Development Boards
Product Training Modules
Product Training Manuals
Blogs
Time-of-Flight Proximity Detection
Eval-ADICUP360
Simplify Wireless Design with EV96B94A Eval Kit
Other Blogs on Development Boards
TechForum
TechForum posts on Development Boards
