This Product Selection Guide contains information to help select products in the Mounting Brackets category on DigiKey.com
Mounting Brackets are designed to hold items together, most often at a right angle to each other. The bracket can be threaded or non-threaded, hinged, or a mounting block with the shape being a short L, tall L, straight, block, or Z shaped made from aluminum, brass, nylon, polypropylene, or steel.
SelectionCharacteristics
Type: Indicates the style of bracket.
Shape: Indicates the shape of the bracket.
Thread/Screw/Hole Size: Indicates the thread size of compatible screws and bolts. For more information on screw sizes see Choosing a Screw by the Thread Size.
Material: Indicates the material composition of the bracket.
ProductExamples
| MFR PART # | 612 |
| DIGIKEY PART # | 36-612-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | MOUNT BRACKET SHORT L 4-40 STEEL |
| MFR PART # | 4332 |
| DIGIKEY PART # | 36-4332-ND |
| DESCRIPTION | MOUNT BRACKET SHORT L 6-32 BRASS |
| MFR PART # | 720-00011 |
| DIGIKEY PART # | 720-00011-ND |
| MANUFACTURER | Parallax Inc. |
| DESCRIPTION | MOUNTING BRACKET TALL L ALUMINUM |
