This Product Selection Guide contains information to help select products in the Screw Grommets category on DigiKey.com
Products in the screw grommet family are designed for use in conjunction with threaded fasteners, and include products designed to provide a flexible, vibration damping interface between a fastener and a fastened object, as well as products designed to facilitate the use of threaded fasteners with thin materials such as sheet metal, with which such fasteners are otherwise incompatible.
SelectionCharacteristics
Screw Size: Indicates the size and/or thread specification of fasteners with which a product is designed for use.
Head Diameter: The diameter of that portion of a product which bears against a fastened surface.
Mounting Hole Diameter: The diameter of the hole that the grommet will mount into.
Head Height: The distance that a fastener protrudes from the surface against which it is installed.
Material : Indicates the material composition of the grommet.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | 765 |
| DIGIKEY PART # | 36-765-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | SCREW GROMMET #6-32 RUBBER BLACK |
| MFR PART # | SI-430-C1002 |
| DIGIKEY PART # | EAR1232-ND |
| MANUFACTURER | Aearo Technologies LLC, a 3M company |
| DESCRIPTION | SCREW GROMMET THERMOPLASTIC |
| MFR PART # | G-410-1 |
| DIGIKEY PART # | EAR1114-ND |
| DESCRIPTION | SCREW GROMMET THERMOPLASTIC BLUE |
