This Product Selection Guide contains information to help select products in the Signal Terminators category on DigiKey.com
Signal Terminators are designed to provide an electrical end to a signal path to prevent the signal from being reflected back into the circuit and cause interference. The types are Cable, DDCA, SCSI, HVD, SE, LVD, Serial, and USB with the number of terminations being 1, 2, 6, 8, 9, 14, 15, 18, or 27.
SelectionCharacteristics
Type: Defines the primary construction style of the device, indicating which type of part it is and determining its general usage.
Number of Terminations: Indicates the number of independent circuits a device can service concurrently.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | LTC1344AIG#PBF |
| DIGIKEY PART # | LTC1344AIG#PBF-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Cable Terminator 6 Terminations 24-SSOP |
| MFR PART # | UCC5638FQPTR |
| DIGIKEY PART # | UCC5638FQPTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | SCSI, LVD, SE Terminator 15 Terminations 48-LQFP (7x7) |
| MFR PART # | UCC5606PWPTR |
| DIGIKEY PART # | 296-29844-2-ND - Tape & Reel (TR) |
| DESCRIPTION | SCSI Terminator 9 Terminations 24-HTSSOP |
| MFR PART # | BH9595FP-YE2 |
| DIGIKEY PART # | BH9595FP-YE2TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Rohm Semiconductor |
| DESCRIPTION | SCSI Terminator 18 Terminations 25-HSOP |
