This Product Selection Guide contains information to help select products in the EMI, Filter Kits category on DigiKey.com
EMI filters suppress noise in electric currents that are conducted through wiring such as power cables and conductor paths. A common mode choke is an EMI filter that blocks high frequency noise common to two or more data or power lines while allowing the desired DC or low-frequency signal to pass. Filter kits allow for experimentation with varying sizes and types of filters including chokes, ferrite disks, plates, beads and chips, transformers, cores, resonators, and saw filters.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Quantity: Indicates the number of pieces contained in the kit.
Mounting Type: Indicates how the devices in the kit can be attached.
Packages Included: Describes the footprints/terminations/sizes of the items in the kit.
Features: These are different capabilities or properties of the devices in the kit such as soft terminations.
ProductExamples
| MFR PART # | K-403 EMI A DEMO |
| DIGIKEY PART # | 240-2224-ND |
| MANUFACTURER | Laird-Signal Integrity Products |
| DESCRIPTION | Ferrite Cores - Cables and Wiring Kit 14 Pieces (14 Values - 1 Each) |
| MFR PART # | 199000052 |
| DIGIKEY PART # | 1934-0199000052-ND |
| MANUFACTURER | Fair-Rite Products Corp. |
| DESCRIPTION | Ferrite Cores - Cables and Wiring Kit 65 Pieces (24 Values - Mixed Quantities) Free Hanging, Snap On |
| MFR PART # | HCTI-HCTC-KIT |
| DIGIKEY PART # | 595-HCTI-HCTC-KIT-ND |
| MANUFACTURER | Signal Transformer |
| DESCRIPTION | Common Mode Chokes Kit 18 Pieces (16 Values - Mixed Quantities) Through Hole |
