This Product Selection Guide contains information to help select products in the Lawn Tools category on DigiKey.com
SelectionCharacteristics
Type: A general description of the item and function.
Construction: Indicates the material from which a device is fabricated.
Handle Type: Describes the handle shape or the material used in the handle.
Handle Length: The measurement of the distance across the longest section of the handle.
Color: The color of the equipment’s main body.
Height (Inches): A description of the nominal Height of the item.
Length (Inches): The measurement of the distance across the longest section of the device.
Width (Inches): A description of the nominal width of the item.
Material - Blade: Indicates the material from which a blade is fabricated.
Tine Shape: Description of the geometry of the item’s tines.
Capacity (Pounds): The size of animal the container is able to hold/store. Given in Pounds.
ProductExamples
MFR PART # | 28252100 |
DIGI-KEY PART # | 3539-28252100-ND |
MANUFACTURER | Ames |
DESCRIPTION | Fiberglass Rake |
MFR PART # | 27022 |
DIGI-KEY PART # | 3539-27022-ND |
MANUFACTURER | GreenWorks |
DESCRIPTION | Dethatcher |
MFR PART # | B2138817 |
DIGI-KEY PART # | 3539-B2138817-ND |
MANUFACTURER | AquaPlumb |
DESCRIPTION | Hose Nozzle |
