Card Extenders
This Product Selection Guide contains information to help select products in the Card Extenders category on DigiKey.com
Card Extenders are boards that have a card edge connector or contact pads on one or both sides of the card. These boards can then be populated with components and connectors for design and test purposes.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Size / Dimension: The physical dimensions of the device. Typically given in Length by Width, in Inches (Millimeters).
Contacts: Indicates number and geometry of signal connections available on a card.
Material: Indicates the material composition of the device.
ProductExamples
MFR PART # VME64-M
DIGI-KEY PART # V2101-ND
MANUFACTURER Vector Electronics
DESCRIPTION Card Extenders VME
DATASHEET Click Here
MFR PART # 2000-EXTM-LF
DIGI-KEY PART # 438-1055-ND
MANUFACTURER Twin Industries
DESCRIPTION Card Extenders PCI
MFR PART # 3690-34-3V
DIGI-KEY PART # V1167-ND
DESCRIPTION Card Extenders 28 contacts per side on 0.125" Centers PCI
MFR PART # 4625-3
DIGI-KEY PART # V1169-ND
If you have any general questions on the specifications for selecting Card Extenders, please reply using the button below. If you have questions on specific Card Extenders please post those questions in the Maker, DIY category.
