This Product Selection Guide contains information to help select products in the Card Rack Accessories category on DigiKey.com
Card rack accessories are designed for use with related card rack products to add features such as brackets, bus strips, conductive strips, covers, EFP modules, EMC contact strips, EMC gaskets, extenders, seals, spacers, rails, insulators, locking hardware, switches, mounting hardware, panels, handles, ejectors, frames, screws, test hardware, and threaded inserts.
SelectionCharacteristics
Accessory Type: The type of accessory being offered.
ProductExamples
| MFR PART # | 60807181 |
| DIGIKEY PART # | 1439-1333-ND |
| MANUFACTURER | Schroff |
| DESCRIPTION | PCB METAL BRACKET |
| MFR PART # | 34560584 |
| DIGIKEY PART # | 1439-1318-ND |
| DESCRIPTION | RR HORIZ RL 84HP HVY INDRCT MNT |
| MFR PART # | EFP204A97 |
| DIGIKEY PART # | V2106-ND |
| MANUFACTURER | Vector Electronics |
| DESCRIPTION | MOD EFP 3UX2.05 FOR 4.5X9.6 PCB |
| MFR PART # | HA14 |
| DIGIKEY PART # | V2031-ND |
| DESCRIPTION | HANDLE EJECTOR PULLTYPE 4PCS/PKG |
| MFR PART # | T107/10 |
| DIGIKEY PART # | V1064-ND |
| DESCRIPTION | BUS STRIPS .08" WIDE 1=10PC PKG |
