This Product Selection Guide contains information to help select products in the Rack Accessories category on DigiKey.com
Products in the rack accessory family are used in an ancillary or supporting fashion in conjunction with equipment mounting racks of standardized sizes. Example items include mounting and mechanical fixation hardware, seismic anchor kits, blanking panels, bonding studs, bus bars, cable guides & cable management products, wheels & casters, fan grills and filters, floor stand kits, gaskets, light kits, grounding kits, mounting rails, and others.
SelectionCharacteristics
Accessory Type: The type, style, or form factor of accessory being offered.
Features: These are different capabilities or properties of the device such as adjustable, EMI shielded, or heavy duty.
For use with/Related Products: Defines other part types, numbers, or series with which this product is designed to be used.
ProductExamples
| MFR PART # | IPV-1116 |
| DIGIKEY PART # | 377-2121-ND |
| MANUFACTURER | Bud Industries |
| DESCRIPTION | Rack Vent Gasket, Nuts |
| MFR PART # | 1421T2 |
| DIGIKEY PART # | HM1480-ND |
| MANUFACTURER | Hammond Manufacturing |
| DESCRIPTION | Rack Rubber Feet Self Adhesive |
| MFR PART # | UGB2/0-414-6 |
| DIGIKEY PART # | 298-10529-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Rack Grounding Kit Ports - 6 |
| MFR PART # | AEK115NDH |
| DIGIKEY PART # | 1441-1268-ND |
| MANUFACTURER | Hoffman Enclosures, Inc. |
| DESCRIPTION | Rack Locking Kit |
| MFR PART # | B018-000-1P5 |
| DIGIKEY PART # | TL1881-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Rack Extension Kit |
| MFR PART # | SCGB-1KT |
| DIGIKEY PART # | 345-SCGB-1KT-ND |
| MANUFACTURER | Wakefield-Vette |
| DESCRIPTION | Rack Bus Bar Kit Bolts, Brackets, Insulators, Washers |
| MFR PART # | SDV280-1 |
| DIGIKEY PART # | HM1612-ND |
| DESCRIPTION | Rack Vent Gasket |
| MFR PART # | DSTOPK |
| DIGIKEY PART # | HM5365-ND |
| DESCRIPTION | Rack Door Stop Kit |
MediaLinks
Blogs
Benefits of Using a Rack to Keep Workbench Tidy
TechForum
Rack Mount unit of length ~ Horizontal Pitch (HP)
1U Measurement
