This Product Selection Guide contains information to help select products in the Current Regulation - Diodes, Transistors category on DigiKey.com
Current regulating diodes (also referred to a constant-current diode, current-limiting diode (CLD), or current-regulating diode (CRD)) maintain a constant current based on their specified value regardless of voltage fluctuations. Current regulating transistors work by regulating its collector and emitter voltage to provide a constant output voltage.
SelectionCharacteristics
Voltage - Anode - Cathode (Vak)(Max): Typically this represents the maximum voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Regulator Current (Max): The maximum current value the device will conduct under normal operation.
Voltage - Limiting (Max): The minimum voltage that must be imposed across the device in order to achieve a current flow at or near the rated value.
Power - Max: Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
Applications: Application is the type of equipment or environment the device is designed for use in.
ProductExamples
| MFR PART # | CMJ1000 TR PBFREE |
| DIGIKEY PART # | 1514-CMJ1000TRPBFREETR-ND - Tape & Reel (TR) |
| MANUFACTURER | Central Semiconductor Corp |
| DESCRIPTION | DIODE CUR REG 100V 1.32MA 500MW |
| MFR PART # | J511 TO-92 2L ROHS |
| DIGIKEY PART # | 4004-J511TO-922LROHS-ND |
| MANUFACTURER | Linear Integrated Systems, Inc. |
| DESCRIPTION | DIODE CUR REG 50V 5.6MA 350MW |
| MFR PART # | 1N5306 |
| DIGIKEY PART # | 150-1N5306-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | DIODE CUR REG 100V 2.42MA 500MW |
| MFR PART # | CDLL5312 |
| DIGIKEY PART # | CDLL5312-ND |
| DESCRIPTION | DIODE CUR REG 100V 4.29MA 500MW |
SchematicSymbol
