This Product Selection Guide contains information to help select products in the Transistors - Special Purpose category on DigiKey.com
Products in the special purpose transistor family are discrete transistors or transistor arrays, with or without additional integrated passive components and internal connections, that are intended for or adapted to some narrow or specific purpose such as current mirroring, balancing series connected capacitor banks, or load switching.
SelectionCharacteristics
Transistor Type: Enumerates product characteristics such as polarity, number of devices incorporated in a package, internal connections among devices, etc.
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Voltage - Rated: Typically this represents the maximum voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Current Rating (Amps): Typically this represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Mounting Type: Indicates how the device is mounted.
ProductExamples
| MFR PART # | ALD810023SCL |
| DIGIKEY PART # | 1014-1257-5-ND |
| MANUFACTURER | Advanced Linear Devices Inc. |
| DESCRIPTION | Transistor Supercapacitor Auto Balancing 4 N-Channel 10.6V 80mA Surface Mount 16-SOIC |
| MFR PART # | BCM61B,215 |
| DIGIKEY PART # | 1727-5454-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Nexperia USA Inc. |
| DESCRIPTION | Transistor Current Mirror 2 NPN (Dual) 45V 100mA Surface Mount SOT-143B |
| MFR PART # | LS313 TO-78 6L |
| DIGIKEY PART # | 4004-LS313TO-786L-ND |
| MANUFACTURER | Linear Integrated Systems, Inc. |
| DESCRIPTION | Transistor General Amplification, High Frequency 2 NPN (Dual) 60V 40mA Through Hole TO-78-6 |
| MFR PART # | NUS5530MNR2G |
| DIGIKEY PART # | NUS5530MNR2GOSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Transistor General Purpose NPN, P-Channel 35V PNP, 20V P-Channel 2A PNP, 3.9A P-Channel Surface Mount 8-DFN (3.3x3.3) |
