This Product Selection Guide contains information to help select products in the Bipolar Transistor Arrays category on DigiKey.com
Bipolar transistor arrays incorporate two or more discrete transistors in a shared package, either as electrically separate entities or with interconnections of some form between them being made inside the device package. Arrays in which the devices contained have closely matched or complementary characteristics, the co-packaged character minimizes temperature differences between devices during operation.
SelectionCharacteristics
Transistor Type: Enumerates product characteristics such as polarity, number of devices incorporated in a package, internal connections among devices, etc.
Current - Collector (Ic) (Max): The maximum current value the device can sustain at its collector without risking damage.
Voltage - Collector Emitter Breakdown (Max): The maximum voltage that can appear between the collector and the emitter of the device without risking damage.
Vce Saturation (Max) @ Ib, Ic: Characterizes the voltage drop between a device’s collector and emitter terminals when a device is operated in saturation. Measured with the base and collector current values shown.
Current - Collector Cutoff (Max): Characterizes current flow through a device’s collector terminal when the device is in an “off” state.
DC Current Gain (hFE) (Min) @ Ic, Vce: Characterizes the ratio of collector current to base current for a bipolar transistor, under DC test conditions including the indicated values of collector current and collector-emitter voltage. Varies significantly among devices and with operating conditions.
Power - Max: Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
Frequency - Transition: Characterizes a BJT’s frequency response, indicating the frequency at which a device’s current gain falls to a value of one.
ProductExamples
| MFR PART # | MBT3946DW1T1G |
| DIGIKEY PART # | MBT3946DW1T1GOSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Bipolar (BJT) Transistor Array NPN, PNP 40V 200mA 300MHz, 250MHz 150mW Surface Mount SC-88/SC70-6/SOT-363 |
| MFR PART # | PMP4201Y,135 |
| DIGIKEY PART # | 1727-5851-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Nexperia USA Inc. |
| DESCRIPTION | Bipolar (BJT) Transistor Array 2 NPN (Dual) Matched Pair 45V 100mA 250MHz 300mW Surface Mount 6-TSSOP |
| MFR PART # | ULN2804A |
| DIGIKEY PART # | 497-2357-5-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Bipolar (BJT) Transistor Array 8 NPN Darlington 50V 500mA 2.25W Through Hole 18-DIP |
| MFR PART # | 2N3810 |
| DIGIKEY PART # | 2N3810-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Bipolar (BJT) Transistor Array 2 PNP (Dual) 60V 50mA 350mW Through Hole TO-78-6 |
SchematicSymbol
MediaLinks
Articles
Transistor Basics
2N3904 NPN Basic Transistor Guide
TechForum
How to Find Replacement BJT, MOSFET, and IGBT Transistors
Bipolar Junction Transistor (BJT) Power Rating
