This Product Selection Guide contains information to help select products in the Bipolar Transistor Arrays, Pre-Biased category on DigiKey.com
Pre-biased bipolar transistor arrays incorporate two or more bipolar transistors, along with resistors connected to each transistor in a manner likely to be useful, typically with one resistor between each transistor’s emitter and base terminals, and another connected to each transistor’s base terminal and a user-accessible pin on the device package.
SelectionCharacteristics
Transistor Type: Enumerates product characteristics such as polarity, number of devices incorporated in a package, internal connections among devices, etc.
Current - Collector (Ic) (Max): The maximum current value the device can sustain at its collector without risking damage.
Voltage - Collector Emitter Breakdown (Max): The maximum voltage that can appear between the collector and the emitter of the device without risking damage.
Resistor - Base (R1): Indicates the nominal value of an integrated resistor connected between a transistor’s base terminal and an external pin on the device package.
Resistor - Emitter Base (R2): Indicates the nominal value of an integrated resistor connected between a transistor’s base and emitter terminals.
DC Current Gain (hFE) (Min) @ Ic, Vce: Characterizes the ratio of collector current to base current for a bipolar transistor, under DC test conditions including the indicated values of collector current and collector-emitter voltage. Varies significantly among devices and with operating conditions.
Vce Saturation (Max) @ Ib, Ic: Characterizes the voltage drop between a device’s collector and emitter terminals when a device is operated in saturation. Measured with the base and collector current values shown.
Current - Collector Cutoff (Max): Characterizes current flow through a device’s collector terminal when the device is in an “off” state.
Frequency - Transition: Characterizes a BJT’s frequency response, indicating the frequency at which a device’s current gain falls to a value of one.
Power - Max: Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
ProductExamples
| MFR PART # | UMH9NTN |
| DIGI-KEY PART # | UMH9NTNTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Rohm Semiconductor |
| DESCRIPTION | Pre-Biased Bipolar Transistor (BJT) 2 NPN - Pre-Biased (Dual) 50V 100mA 250MHz 150mW Surface Mount UMT6 |
| MFR PART # | PUMD3,135 |
| DIGI-KEY PART # | 1727-PUMD3,135TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Nexperia USA Inc. |
| DESCRIPTION | Pre-Biased Bipolar Transistor (BJT) 1 NPN, 1 PNP - Pre-Biased (Dual) 50V 100mA 300mW Surface Mount 6-TSSOP |
| MFR PART # | MUN5135DW1T1G |
| DIGI-KEY PART # | MUN5135DW1T1GOSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Pre-Biased Bipolar Transistor (BJT) 2 PNP - Pre-Biased (Dual) 50V 100mA 250mW Surface Mount SC-88/SC70-6/SOT-363 |
| MFR PART # | RN2703JE(TE85L,F) |
| DIGI-KEY PART # | RN2703JE(TE85LF)TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Toshiba Semiconductor and Storage |
| DESCRIPTION | Pre-Biased Bipolar Transistor (BJT) 2 PNP - Pre-Biased (Dual) (Emitter Coupled) 50V 100mA 200MHz 100mW Surface Mount ESV |
MediaLinks
Articles
Transistor Basics
2N3904 NPN Basic Transistor Guide
TechForum
How to Find Replacement BJT, MOSFET, and IGBT Transistors
Bipolar Junction Transistor (BJT) Power Rating
