Current Regulating Diodes also are known as CRD. A CRD’s purpose is to maintain a constant flow of current, even when there are voltage fluctuations.
From our home page you may find them this way: Product Index > Integrated Circuits (ICs) > PMIC - Current Regulation/Management
Here is a guideline to filter your options down:
- Current output.
- Active and In-stock
- Mounting type or package.
- Sensing Method
After these first four, I have found most people have more wiggle room. Things can be tweaked perhaps a larger range for voltage input and operating temperatures. Of course, there are always going to be exceptions to the rules, maybe you need to have the accuracy of the diode at 1%. This will change the filtering order.
