This Product Selection Guide contains information to help select products in the Machine Safety - Laser Scanners category on DigiKey.com
Laser scanners establish a safety zone in hazardous environments for human workers. As a worker approaches a machine or system, laser scanners can stop or slow down the operation ensuring safety. Additionally, laser scanners are used in collision avoidance in automated guided vehicles (AGV) as an added measure of safety for human operators.
SelectionCharacteristics
Protection Range: When an obstacle is detected in this zone main actuator state is changed.
Warning Range: When an obstacle is detected in this zone warning signals are outputted.
Number of Outputs and Type: Indicates the number of control outputs provided by a device and identifies the manner of their implementation.
Sensing Angle: Indicates the degrees of sensing view around the device.
Detection Capability: The resolution the device is able to sense obstructions.
Number of Monitor Fields: Number of areas within the range of the device that are tracked and can provide a unique output.
Response Time: The amount of time it takes for the sensor to respond to a change in input.
Safety Category: Standard(s) of safety assurance a device is designed to meet or support; Category (x) PL(Performance Level)x and SIL(Safety Integrity Level)x have specific meanings defined by various standards organizations.
Features: These are different capabilities or properties of the device such as including brackets or a cable.
ProductExamples
| MFR PART # | SE2L-H05LP |
| DIGIKEY PART # | 1885-1012-ND |
| MANUFACTURER | IDEC |
| DESCRIPTION | Safety Laser Scanner 5m 270° |
| MFR PART # | SX5-R |
| DIGIKEY PART # | 2170-SX5-R-ND |
| MANUFACTURER | Banner Engineering Corporation |
| DESCRIPTION | Safety Laser Scanner 5.5m 275° |
| MFR PART # | OS32C-BP-DM-4M |
| DIGIKEY PART # | Z6212-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | Safety Laser Scanner 4m 270° |
| MFR PART # | S32B-3011BA |
| DIGIKEY PART # | 1882-1387-ND |
| MANUFACTURER | SICK, Inc. |
| DESCRIPTION | Safety Laser Scanner 3m 270° |
MediaLinks
Videos
S300 Mini safety laser scanner from SICK
Articles
Comparing Laser Scanner Applications
Reducing Robot Risk: How to Design a Safe Industrial Environment
Basic Understanding of Safety Circuits
