This Product Selection Guide contains information to help select products in the Exit Signs and Emergency Lights category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the device.
Voltage - Input: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Power (Watts): Typically this rating indicates the nominal amount of power you would expect the device to consume during normal operation.
Width (Inches): Indicates the overall width of the device.
Height (Inches): Indicates the overall height of the device.
Depth (Inches: Indicates the overall depth of the device.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | JLEC2RW |
| DIGIKEY PART # | 3539-JLEC2RW-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | COMBO LED EMERGENCY EXIT SIGN, R |
| MFR PART # | C215RB |
| DIGIKEY PART # | 3539-C215RB-ND |
| MANUFACTURER | National Marker Company |
| DESCRIPTION | CAUTION WATCH OUT FORKLIFT TRUCK |
| MFR PART # | B664306 |
| DIGIKEY PART # | 3539-B664306-ND |
| MANUFACTURER | IndustrialSupplies.com |
| DESCRIPTION | 4 INCH VIBRATING BELL 120V AC |
