This Product Selection Guide contains information to help select products in the Hot Swap Controllers category on DigiKey.com
PMIC - Hot Swap Controllers are semiconductors that provide the in-circuit protection and control features needed to allow other components to be inserted or removed from a circuit while there is live power. Useful in computer networking and general-purpose power systems, hot-swap controllers are mainly differentiated by features such as output current, number of controlled channels, and special features such as auto-retry, fault timeout, and protections.
SelectionCharacteristics
Number of Channels: The number of individual channels available within the device.
Internal Switch(s): Indicates whether or not a device integrates the power transistor(s) needed for manipulation of the power source a device is intended to control.
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Features: These are different capabilities or properties of the device such as auto retry, fault timeout, or UVLO.
Programmable Features: These are different capabilities or properties of the device whose behavior or functionality can be controlled or modified programmatically.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Output (Max): The maximum amount of current that can be output by the device.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer specific. It is typically best to use the actual dimensions from the datasheets rather than use this terminology when designing your circuit.
ProductExamples
| MFR PART # | ADM1270ACPZ-R7 |
| DIGIKEY PART # | ADM1270ACPZ-R7TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Hot Swap Controller 1 Channel General Purpose 16-LFCSP-WQ (3x3) |
| MFR PART # | RT1720GF |
| DIGIKEY PART # | 1028-1445-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Richtek USA Inc. |
| DESCRIPTION | Hot Swap Controller 1 Channel General Purpose 10-MSOP |
| MFR PART # | MP5048GU-P |
| DIGIKEY PART # | 1589-MP5048GU-PTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Monolithic Power Systems Inc. |
| DESCRIPTION | Hot Swap Controller 1 Channel General Purpose 30-QFN (5x5) |
| MFR PART # | LT1640AHCN8 |
| DIGIKEY PART # | LT1640AHCN8-ND |
| DESCRIPTION | Hot Swap Controller 1 Channel -48V 8-PDIP |
MediaLinks
Videos
Hot Swap Technology
Articles
PMBus Provides Protection and Power Control for High-Reliability Systems
Using the PMbus to Watch for Power Problems
Product Training Modules
Hot-Swap High-Voltage - Microchip
Hot Swap Design - ADI
TechForum
Hot swap applications need a TVS diode?
Limiting current using an integrated MosFET
