This Product Selection Guide contains information to help select products in the Industrial Lighting - Pick to Light category on DigiKey.com
Pick to light, or pick by light, is an order fulfillment solution that indicates the product to be picked using lights. Items in this category can be narrowed down by supply voltage, illumination type and color, switch function, and more.
SelectionCharacteristics
Actuator Type: Indicates the style and configuration of the actuator of the device.
Circuit: Describes device function in terms of a number of poles and throws, as is typical for mechanical switches. For more information please see: Switch Basics, Examples of Pole and Throw
Switch Function: Refers to the specific operation or behavior of a switch, indicating the primary purpose or mode of operation. For more information please see: Switch Basics, Examples of Pole and Throw
Illumination Type, Color: Indicates the illumination source being used in the device and the color of the overall illuminative effect.
Features: These are different capabilities or properties of the device such as led display.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Response Time: How long the device takes to respond to input stimulus.
Termination Style: Selection of termination style used to connect the device to a system, such as cable leads or screw terminals.
Panel Cutout Dimensions: Refers to the measurements or dimensions of the opening or cutout in the panel.
Ingress Protection: IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
IP Ratings
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Approval Agency: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
ProductExamples
| MFR PART # | K50PTFKQP |
| DIGIKEY PART # | 2170-K50PTFKQP-ND |
| MANUFACTURER | Banner Engineering Corporation |
| DESCRIPTION | K50 PRO IO-LINK MULTI TOUCH SEN |
| MFR PART # | PTL110S-T-QP150 |
| DIGIKEY PART # | 2170-PTL110S-T-QP150-ND |
| DESCRIPTION | PTL NODE 100MM TOUCH M12-4 |
| MFR PART # | S22AMTSRGB7 |
| DIGIKEY PART # | 2170-S22AMTSRGB7-ND |
| DESCRIPTION | S22 TOUCH SW BIMODE NO MULTI CLR |
MediaLinks
Videos
Banner PTL110 Series of Scalable, Versatile Pick-to-Light Devices
