This Product Selection Guide contains information to help select products in the Racks category on DigiKey.com
Products in the rack family are equipment mounting and enclosure systems based on standardized sets of equipment dimensions, used to mechanically assemble and contain mechanically compatible system subcomponents from various manufacturers in an organized and mechanically secure fashion. Open and enclosed racks are included and are offered in floor standing, wall mount, console, and other styles.
SelectionCharacteristics
Type: The type or form factor of rack being offered.
Style: The physical style and construction of the rack.
Number of Units: How many standard rack units, or U, of equipment the rack can accommodate.
Dimensions - Panel: The dimensions of the interior space within the enclosure; the size of the largest rectangular object that could fit within.
Dimensions - Overall: The dimensions of the outer rack equipment itself; the amount of space the rack physically takes up.
Door: Indicates the material from which the enclosure’s doors are made.
Features: These are different capabilities or properties of the device such as adjustable, dual door, or wall mount.
Mounting Rails: Indicates the number of integrated/included mounting rails for securing items within the rack.
Ventilation: Indicates whether or not a component includes holes, slots, or other provisions to facilitate airflow.
Material: The dominant material of the rack.
Color: The dominant color of the rack.
ProductExamples
| MFR PART # | XDR8419-312N |
| DIGIKEY PART # | XDR8419-312N-ND |
| MANUFACTURER | Belden Inc. |
| DESCRIPTION | Metal, Steel Open Rack Open Rack, Single Frame 84.000" H (2133.60mm) Black |
| MFR PART # | WNC-5641 |
| DIGIKEY PART # | 377-1988-ND |
| MANUFACTURER | Bud Industries |
| DESCRIPTION | Metal, Steel Cabinet Rack Enclosed, Bottom, Front, Sides, Top 11.811" L x 23.622" W x 23.622" H (300.00mm x 600.00mm x 600.00mm) Black |
| MFR PART # | VWR6UWH |
| DIGIKEY PART # | 164-VWR6UWH-ND |
| MANUFACTURER | Hammond Manufacturing |
| DESCRIPTION | Metal, Steel Open Rack Open Rack, Single Frame 12.400" L x 20.370" W x 10.500" H (314.96mm x 517.40mm x 266.70mm) Black |
| MFR PART # | T24PPR |
| DIGIKEY PART # | T24PPR-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | Metal, Steel Open Rack Open Rack, Double Frame 18.000" L x 20.750" W x 24.000" H (457.20mm x 527.05mm x 609.60mm) Black |
MediaLinks
Articles
Rack Basics: Everything You Need - Tripp Lite
Product Training Modules
Modified Enclosures - Bud Industries
Blogs
Benefits of Using a Rack to Keep Workbench Tidy
Keeping it Cool
Forced-Air Cooling with Fans
TechForum
Rack Mount unit of length ~ Horizontal Pitch (HP)
1U Measurement
