This Product Selection Guide contains information to help select products in the Pads, Sheets category on DigiKey.com
Materials designed to provide thermal transfer between components and the heat sink to which they are attached. They are made from various materials and thicknesses which determines their thermal conductivity and/or resistivity. They can come with an adhesive on one or both sides to aid in maintaining contact with the surface to which they are applied.
SelectionCharacteristics
Usage: The typical expected usage for which the pad was designed.
Type: Indicates the style and configuration of the pad.
Shape: Indicates the overall shape of the pad.
Outline: Indicates the dimensions for the outline of the pad.
Thickness: Indicates the overall thickness of the pad.
Material: Indicates the material composition of the pad.
Adhesive: Indicates if a product has strong or weak adhesive qualities, and the presence of such on one or both sides of the material.
Backing, Carrier: Indicates the material composition of the carrier of the pad.
Color: The dominant color of the device.
Thermal Resistivity: Characterizes heat transfer resistance of a thermal interface using a part or material under manufacturer-defined test conditions, which are typically chosen to be representative of an expected application.
Thermal Conductivity: Characterizes a material’s thermal energy transfer properties; typically measured using a standard method such as ASTM D5470.
ProductExamples
| MFR PART # | SPK4-0.006-00-58 |
| DIGIKEY PART # | BER220-ND |
| MANUFACTURER | Bergquist |
| DESCRIPTION | THERM PAD 19.05MMX12.7MM GRAY |
| MFR PART # | CP33-TO247-28.5-17.5-5.8-0.45 |
| DIGIKEY PART # | 1168-CP33-TO247-28.5-17.5-5.8-0.45-ND |
| MANUFACTURER | t-Global Technology |
| DESCRIPTION | THERM PAD 28.5X17.5X5.8MM GRAY |
| MFR PART # | EYG-S091207 |
| DIGIKEY PART # | P13688-ND |
| MANUFACTURER | Panasonic Electronic Components |
| DESCRIPTION | THERM PAD 115MMX90MM GRAY |
MediaLinks
MediaLinks
Videos
How to Apply Thermal Interface Material: Thermal Tape
Articles
Thermal Management Introduction
What to Know When Procuring Thermal Solutions
Don’t Forget About Thermal Interface Materials
Device Thermal Coupling on a PCB
Product Training Modules
Thermal Interface Product Selection - T-Global
Thermal Interface Materials - Würth Elektronik
Thermal Interface Materials - Bergquist
Installation Procedures for Thermal Management Materials
TechForum
Do I need a Thermal Interface for my Heat Sink?
