This Product Selection Guide contains information to help select products in the Reflectors category on DigiKey.com
Products in the optical reflector category are used to alter the spatial pattern of light intensity produced by some light source, most commonly an LED. They are used to increase system efficacy by redirecting light emitted by a source in unwanted directions along a path where such light, which would otherwise be wasted, can serve a useful purpose.
SelectionCharacteristics
Style/Size: Indicates the shape and physical dimensions of the device.
Optical Pattern: Provides a basic description of how a reflector shapes light emitted from a compatible emitter.
For Use With/Related Manufacturer: Defines other part types, numbers, or series with which this product is designed to be used.
Viewing Angle: Indicates the angle of light emitted from the LEDs.
ProductExamples
| MFR PART # | CA10928_BOOM-M |
| DIGIKEY PART # | 711-1066-ND |
| MANUFACTURER | Ledil |
| DESCRIPTION | LENS BOOM REFLECTOR MEDIUM MC-E |
| MFR PART # | CA11183_BROOKE-W |
| DIGIKEY PART # | 711-1083-ND |
| DESCRIPTION | REFLECTOR 45MM RND WIDE |
| MFR PART # | CA17283_ELLA-30-WW |
| DIGIKEY PART # | 711-CA17283_ELLA-30-WW-ND |
| DESCRIPTION | ASSEMBLYROUND1 POS16.0MM (D)20.0 |
MediaLinks
Articles
Articles on Reflectors
TechForum
Do I need a Reflector for my Photoelectric Sensor
