This Product Selection Guide contains information to help select products in the Light Pipes category on DigiKey.com
Light pipes are products used to channel optical energy between a light source and a point some distance away where light is desired for some purpose. A common use is for routing light between an LED on a printed circuit board and an aperture in a product control panel or enclosure for purposes of providing a visual indication of operational status.
SelectionCharacteristics
Color: Indicates the color(s) of the light pipe.
Configuration: Indicates the arrangement for multiple light pipes.
Lens Style: Characterizes the shape of a device’s optical emitting surface.
Lens Size: Defines the overall dimensions of the lens.
ProductExamples
| MFR PART # | LPA-C041301S-30 |
| DIGIKEY PART # | 67-2318-ND |
| MANUFACTURER | Lumex Opto/Components Inc. |
| DESCRIPTION | 3MM QUAD UNIT VERTICAL SMT LIGHT |
| MFR PART # | 5151094F |
| DIGIKEY PART # | 350-2186-ND |
| MANUFACTURER | Dialight |
| DESCRIPTION | LIGHT PIPE 3MM BI-LEVEL |
| MFR PART # | LCS_132_CTP |
| DIGIKEY PART # | LCS_132_CTP-ND |
| MANUFACTURER | Visual Communications Company - VCC |
| DESCRIPTION | LIGHTPIPE ASSY THREADED SEALED |
MediaLinks
Videos
Synthesthesia [Maker Update] | Maker.io
More Videos on Light Pipes
Articles
Articles on Light Pipes
Product Training Modules
Product Training Modules on Light Pipes
Blogs
Blogs on Light Pipes
TechForum
How do Light Pipes work?
How to choose the Right Light Pipe
More TechForum posts on Light Pipes
