This Product Selection Guide contains information to help select products in the Assorted Tool Kits category on DigiKey.com
Assorted Tool Kits are groupings of hand tools that are used in combination with each other to provide a specific result. Some of the usages are adjustment-alignment, audio/video, automotive, broadcast applications, Cat5 data communication, coaxial cable, crimping, computer service, D-sub SEK connector, data cable, Datacom networking, electrical, Ethernet, fiber optic, general purpose, industrial, mobile, modular connectors, soldering, and wiring.
SelectionCharacteristics
Usage: Application is the type of equipment or environment the device will be used in; they are typically tested to ensure certain minimum standards for the application they are intended for.
Contents Indicates items included with purchase.
ProductExamples
| MFR PART # | 65200 |
| DIGIKEY PART # | 1742-65200-ND |
| MANUFACTURER | Klein Tools, Inc. |
| DESCRIPTION | ELECTRICIAN’S MINI RATCHET SET, |
| MFR PART # | PA901081 |
| DIGIKEY PART # | PA901081-ND |
| MANUFACTURER | Tempo Communications |
| DESCRIPTION | KIT COAX DELUXE |
| MFR PART # | KDEMOA5-E.IT |
| DIGIKEY PART # | 2014-KDEMOA5-E.IT-ND |
| MANUFACTURER | Ideal-tek S.A. |
| DESCRIPTION | TOOLS KIT FOR ELECTRONICS |
