This Product Selection Guide contains information to help select products in the Evaluation Boards - Embedded - Complex Logic (FPGA, CPLD) category on DigiKey.com
Evaluation Boards for Embedded Complex Logic (FPGA, CPLD) are a programmable boards comprised of an array of logic blocks, input/output blocks, and macro cells. Both FPGAs and CPLDs have a large number of gates available for the implementation of moderately complicated data processing devices.
SelectionCharacteristics
Type: Indicates which base logic device format the evaluation board is designed to demo.
Platform: Indicates which development platform or IDE the evaluation board is designed to work within.
Contents: Describes the physical contents, items, and peripherals that the device ships with.
ProductExamples
| MFR PART # | ICE40HX1K-STICK-EVN |
| DIGIKEY PART # | 220-2656-ND |
| MANUFACTURER | Lattice Semiconductor Corporation |
| DESCRIPTION | iCE40 HX FPGA iCEstick iCE40HX1K iCE40™ HX FPGA Evaluation Board |
| MFR PART # | P0466 |
| DIGIKEY PART # | P0466-ND |
| MANUFACTURER | Terasic Inc. |
| DESCRIPTION | MAX 10 FPGA DE10-Lite 10M50DA MAX® 10 FPGA Evaluation Board |
| MFR PART # | 410-352 |
| DIGIKEY PART # | 1286-1172-ND |
| MANUFACTURER | Digilent, Inc. |
| DESCRIPTION | Arty S7-50 Spartan-7 FPGA XC7S50 Spartan®-7 FPGA Evaluation Board |
| MFR PART # | SK-KR260-G |
| DIGIKEY PART # | 122-SK-KR260-G-ND |
| MANUFACTURER | AMD |
| DESCRIPTION | Kria KR260 Robotics Starter SM-K26, XCK26 Zynq® UltraScale+™ Kria™ FPGA + MCU/MPU SoC Evaluation Board |
MediaLinks
Videos
MicroSemi PolarFire Evaluation Kit | DigiKey Daily
Accelerate innovation with Intel System on Modules
Articles
Programmable Logic for the Masses Lattice MACHXO2
Fundamentals of FPGAs: What Are FPGAs and Why Are They Needed?
Design Gateway’s IP Cores AI Development
Product Training Modules
Intel® Nios® II Embedded Evaluation Kit - Intel®
Blogs
Accelerate Compute-Demanding Applications
TechForum
Digilent Genesys 2 Kintex-7 FPGA Evaluation Board
