This Product Selection Guide contains information to help select products in the Thermal Management category on DigiKey.com
Thermal Management ICs are semiconductor device that controls the power in a circuit based on temperature. The functions of these ICs are Fan Control, Hardware Monitor, Temp Monitoring System, Thermal Monitor, Thermocouple Amplifier, Thermocouple Conditioner, and a Thermometer – Thermostat. The sensing temperature is from -260°C to +1800°C with an output type of I2C, SMBus, Active low/Active High, Analog Voltage, Open Drain, PWM, SPI, 2-Wire Serial, and Parallel – Serial.
SelectionCharacteristics
Function: Indicates the primary functionality of the device.
Sensor Type: Indicates which style of sensor the device is designed to utilize.
Sensing Temperature: The temperature range the device is capable of detecting.
Accuracy: How closely measured temperature corresponds to actual temperature.
Topology: The internal circuit configuration of the device, determining characteristics of its behavior and functionality.
Output Type: The communication protocol the device uses to transmit its information to the host system it’s part of.
Output Alarm: Indicates the presence of an output that signals when the sensed temperature has exceeded some threshold.
Output Fan: Indicates the presence of an output intended for controlling the speed of an external fan.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
MFR PART # | MCP9844T-BE/MNY |
DIGI-KEY PART # | MCP9844T-BE/MNYTR-ND - Tape & Reel (TR) |
MANUFACTURER | Microchip Technology |
DESCRIPTION | Temp Monitoring System (Sensor) -40°C ~ 125°C Internal Sensor 2-Wire Serial, I²C Output 8-TDFN (2x3) |
DATASHEET | Click Here |
MFR PART # | MAX6684ESA+T |
DIGI-KEY PART # | MAX6684ESA+TTR-ND - Tape & Reel (TR) |
MANUFACTURER | Analog Devices Inc./Maxim Integrated |
DESCRIPTION | Fan Control, Temp Monitor Internal Sensor Active Low/Open Drain Output 8-SOIC |
MFR PART # | LM96080CIMT/NOPB |
DIGI-KEY PART # | LM96080CIM/NOPB-ND |
MANUFACTURER | Texas Instruments |
DESCRIPTION | Hardware Monitor -40°C ~ 125°C, External Sensor Internal and External Sensor 2-Wire Serial, I²C Output 24-TSSOP |
MFR PART # | ADT7462ACPZ-REEL |
DIGI-KEY PART # | ADT7462ACPZ-REELOSTR-ND - Tape & Reel (TR) |
MANUFACTURER | onsemi |
DESCRIPTION | Fan Control, Temp Monitor -40°C ~ 125°C, External Sensor Internal and External Sensor SMBus Output 32-LFCSP-VQ (5x5) |
