This Product Selection Guide contains information to help select products in the Sensor, Transducer Amplifiers category on DigiKey.com
Sensor Amplifiers use application specific circuitry to condition a sensor’s raw output signal into a usable form through amplification and conversion. Output types include analog voltage or current, digital, NPN or PNP transistor, linear and relay contact(s). Common mounting types include bracket, cable, chassis, DIN rail, board surface, and through-hole.
SelectionCharacteristics
Specifications to determine which amplifier sensor is right for your application.
Amplifier Type: Refers to the type of application or function the amplifier is designed for.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Output Type: Indicates the type of electrical signal the device provides, such as analog or digital.
Current - Supply: Typically this represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
ProductExamples
| MFR PART # | E32-T11N 2M |
| DIGIKEY PART # | Z9276-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | SENSOR FIBER OPTIC AMP FLEX 2M |
| MFR PART # | MPC3 |
| DIGIKEY PART # | 2170-MPC3-ND |
| MANUFACTURER | Banner Engineering Corporation |
| DESCRIPTION | Fiber Amp Sensor Amplifier DIN Rail |
| MFR PART # | ASTC0000 |
| DIGIKEY PART # | RLC207-ND |
| MANUFACTURER | Red Lion Controls |
| DESCRIPTION | Standard Sensor Amplifier Through Hole |
