This Product Selection Guide contains information to help select products in the Flux, Flux Remover category on DigiKey.com
Flux paste, spray or liquid, when applied to materials undergoing soldering, prevents the formation of metal oxides and aids in cleaning surfaces which prevents beading and allows the solder to flow around and adhere to the material. Some fluxes leave post soldering residue that is removable using rosin activated, ionic, or lead-free flux remover.
SelectionCharacteristics
Type: A general description of the product.
Form: Indicates how the material is packaged and sold.
Shelf Life: Indicates the period of time for which material properties and performance are expected to remain within the manufacturer’s specifications, when stored and handled as indicated.
Shelf Life Start: Indicates the point from which the clock starts on the manufacturer’s specified shelf life.
Storage/Refrigeration Temperature: Indicates the temperature the product needs to be stored at to remain within manufacturer specifications. Improper storage temperature may reduce shelf life, alter the specifications, or damage or destroy the product.
Shipping Info: Indicates whether or not shipping restrictions apply to the material.
ProductExamples
| MFR PART # | 8341-10ML |
| DIGIKEY PART # | 473-1117-ND |
| MANUFACTURER | MG Chemicals |
| DESCRIPTION | Flux - No Clean |
| MFR PART # | CQ4LF-1.0 |
| DIGIKEY PART # | CQ4LF-1.0-ND |
| MANUFACTURER | Chip Quik Inc. |
| DESCRIPTION | Flux - No Clean, Liquid |
| MFR PART # | 1621-10S |
| DIGIKEY PART # | 1873-1621-10S-ND |
| MANUFACTURER | Techspray |
| DESCRIPTION | Flux Remover - Lead Free |
MediaLinks
Videos
How to Refill a Flux Pen
Chipquik SMD Removal Procedure
How to Remove SMD Components Using a Soldering Iron
Articles
What is Solder Flux and Why You Should Use It
Recommended Soldering Techniques
Blogs
How to Solder with Flux
Solder and Flux
TechForum
Fluxing and Cleaning Consideration in Soldering
Why Soldering Stainless Steel and Using Acid Flux Are Unsuitable for Electrical Applications
How can I prevent solder flux intrusion?
Good health practices when using Flux
Why use flux when soldering?
