Flux aids in the soldering and desoldering process by removing oxides which form on the surface of metals that are being soldered. Flux helps the wetting ability of solder which causes it to flow better over surfaces without balling up.
Related topics
| Topic | Replies | Views | Activity | |
| Why use flux when soldering? | 1 | 64366 | November 26, 2020 | |
| Flux, Flux Remover | 0 | 472 | July 24, 2023 | |
| Fluxing and Cleaning Consideration in Soldering | 0 | 578 | May 9, 2024 | |
| Using Flux with Different Solders | 1 | 1538 | March 28, 2017 | |
| 납땜 시 왜 플럭스를 사용하는가? | 0 | 16787 | February 3, 2021 |
