This Product Selection Guide contains information to help select products in the Surge Suppression Ics category on DigiKey.com
Surge Suppression ICs are designed to keep electrical devices safe from excess voltage and/or current. Components in this family are designed using semiconductor materials. The characteristics are clamping voltage, technology, number of circuits, applications, and mounting type. The technologies are external or internal switch with the number of circuits being 1, 2, 3, or 4. Target applications are automotive, Ethernet, general purpose, portable equipment, SLIC, USB, USB OTG, and others.
SelectionCharacteristics
Voltage - Clamping: Characterizes the maximum value to which a protection device limits an applied voltage. Measured under manufacturer-defined test conditions.
Technology: Defines whether the device integrates an internal switching function, or whether it relies on an external switch.
Number of Circuits: Indicates the number of circuits of similar functions that are implemented within the device.
Applications: Application is the type of equipment or environment the device will be used in, they are tested and typically rated by a third party to ensure certain minimum standards for the application they are intended for. You could use one with a higher rating, but you cannot use one with a lower rating as it will fail in that application. For example, you could use a medically rated device to replace a commercial device, but you cannot replace the medical device with the commercial device.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | TCS-DL004-250-WH |
| DigiKey PART # | TCS-DL004-250-WHTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Bourns Inc. |
| DESCRIPTION | SUPPRESSOR TCS DUAL 40V 250MA |
| MFR PART # | LT4356CMS-1#TRPBF |
| DigiKey PART # | 505-LT4356CMS-1#TRPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC OVERVOLT PROT REG 10-MSOP |
| MFR PART # | TCPP01-M12 |
| DigiKey PART # | 497-TCPP01-M12TR-ND - Tape & Reel (TR) |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | TYPE-C PORT PROTECTION 12QFN |
| MFR PART # | TVS2201DRBR |
| DigiKey PART # | 296-TVS2201DRBRTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | IC UNIDIR PRECISION SURGE DIODE |
MediaLinks
Articles
Protecting MCU I/O Lines from ESD
Protecting USB From Power Surges
Product Training Modules
Transient Current Suppressors - Bourns
