This Product Selection Guide contains information to help select products in the Batteries category on DigiKey.com
Nonvolatile static RAM (SRAM) memory and some portable devices require an onboard backup source of power to prevent data loss. Lithium or lithium cell batteries in snap-in, surface mount or through-hole configuration can last up to a decade as power backups. Some use mounting bases for simplified replacement or include a crystal for timekeeping RAMs.
SelectionCharacteristics
Battery Chemistry: Indicates the chemical system on which a cell or battery is based.
Mounting Type: Indicates how the device is attached
Package / Case: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the device and other system components.
ProductExamples
MFR PART # | DS9034PC+ |
DIGIKEY PART # | DS9034PC±ND |
MANUFACTURER | Analog Devices Inc./Maxim Integrated |
DESCRIPTION | PCM W/O CRYSTAL NV SRAM SNAP-ON |
DATASHEET | Click Here |
MFR PART # | M4Z28-BR00SH1 |
DIGIKEY PART # | 497-3689-5-ND |
MANUFACTURER | STMicroelectronics |
DESCRIPTION | IC SNAPHAT BATTERY 48MAH 28-SOIC |
SchematicSymbol
