This Product Selection Guide contains information to help select products in the Terminal Junction Systems category on DigiKey.com
Products in the terminal junction system family are a system of environmentally resistant interconnect products used for the interconnection of wiring and incorporation of passive components, commonly pursuant to or derived from the MIL-T-81714 standard. Sizing designations for the contact systems used in this interconnect family are similar to those used for MIL-spec circular connectors.
SelectionCharacteristics
Type: Indicates the type of terminal junction device.
Contact Size: Indicates the size(s) of the contacts accommodated by a housing, or sold as a standalone product. Size designations generally correspond to the gage size of the largest wire accommodated.
Module Capacity: The number of contacts that will fit in a housing.
Size / Dimension: The size of the main body of the device.
ProductExamples
| MFR PART # | TJSE22517 |
| DIGIKEY PART # | APC1920-ND |
| MANUFACTURER | Amphenol PCD |
| DESCRIPTION | Connector Wire Splice, Resistor Contact Size 22 |
| MFR PART # | M81714/60-20-04 |
| DIGIKEY PART # | 1508-1101-ND |
| MANUFACTURER | TE Connectivity Deutsch Connectors |
| DESCRIPTION | Connector Module Contact Size 20 |
| MFR PART # | 110420202 |
| DIGIKEY PART # | 623-00110420202-ND |
| MANUFACTURER | Amphenol Air LB |
| DESCRIPTION | Connector Contact Contact Size 20 |
