This Product Selection Guide contains information to help select products in the Universal Bus Functions category on DigiKey.com
Products in the universal bus function family are component-level products used for handling or operating on a series of (usually 8 or more) parallel logic signals known as a bus. Functions performed include temporary storage of data to be transmitted or received, buffering to allow a device such as a microprocessor having a limited output current capacity to transmit data over long interconnects at high speed, rotation or shifting of bit order within the bus, and others.
SelectionCharacteristics
Logic Type: Describes the logic functions used within the circuit.
Number of Circuits: Indicates the number of circuits of similar functions that are implemented within the device.
Current - Output High, Low: The maximum recommended current flow through a device’s output pin. Multiple values reflect ratings that differ depending on the direction of the current flow.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | CD74HCT299E |
| DIGIKEY PART # | 296-33146-5-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Shift Shift Register 2 Element 8 Bit 20-PDIP |
| MFR PART # | SN74ALVCH16835DGGR |
| DIGIKEY PART # | 296-1149-2-ND - Tape & Reel (TR) |
| DESCRIPTION | Universal Bus Driver 18-Bit 56-TSSOP |
MediaLinks
Videos
Kycon IP67 USB Type-C receptacles
MCC USB-231 / MCC USB-234 USB DAQ Devices | Datasheet Preview
Waterproof Micro USB 2.0-HD
onsemi USB Type-C Solutions | Digi-Key Daily
All You Need to Know About USB Connectors and Standards
Introduction to USB Type-C
11 Myths About USB Type-C Part 1
11 Myths About USB Type-C Part 2
Articles
Decoding the USB Standards from 1.0 to 4.0
Use Eval Kits to Develop and Test USB Type-C and USB PD Products in a Controlled Environment
USB Type-C, USB PD, and USB 3.1 Gen 2: New Standards in Speed and Power
Get Started with USB-C Power Delivery
Designing In USB Type-C and Using Power Delivery for Rapid Charging
A Basic Guide to USB
Product Training Modules
USB 3-1 Type A and USB 3-1 Type C
SuperSpeed USB 3.0 Solutions
Blogs
Webinar: Isolated USB Repeaters with Texas Instruments and Digi-Key
Basics of USB
TechForum
USB
